NTP Problems
Dec 12th, 2007
Good day, I'm shaping the NTP on my equipment catalyst 2950, 2960,3500 and 4500 but the problem is that I introduced that achievement configure the date but not the time, not if it is the software that is used or equipment.
If anyone knows an NTP Software which is 100% compatible serious helpful
In advance thank!
Danilo Dy Fri, 12/14/2007 - 20:24
I'm not sure if I understand your problem and question as well.
But here is a free NTP software that you can install in any Windows Server/Workstation. You can sync it to NTP Pool and you can sync your network devices to it.
http://www.meinberg.de/english/sw/ntp.htm
This beats editing Windows Registry for Time Service and still won't work.
Dandy
