error starting IOS on 3660 cisco router
Dec 12th, 2007
i've upgraded 3660 router flash memory from 8 mb to 2x32 flash simm i uploaded ios version 12.1 from xmodem -r its size 5 mb, upload process completed successfully and the router booted normally cuz the IOS on the DRAM
after that i uploaded another version of IOS 12.3 after finished upload the router booted and an error message interrupted the boot process
"*** Bus Error (Load) Exception ***
Access address = 0x8e032958
PC = 0x8000b740, Cause = 0x401c, Status Reg = 0x3041f003
*** CPU Out-of-range Interrupt ***
Access address high = 0x0, low = 0xe032958
PC = 0xbfc10134, Cause = 0x4000, Status Reg = 0x3041f003
monitor: command "boot" aborted due to exception"
so please advise what to do
thanks in advanced
JORGE RODRIGUEZ Wed, 12/12/2007 - 15:24
  • Green, 3000 points or more
Indeed not the kind of messages one likes to see when upgrading codes, does the route goes into rommon> if it does try recoverying , here is a link for rommon recovery..
http://www.cisco.com/en/US/docs/routers/access/3600/hardware/installation/guide/3600appB.html
Take a look at ios bugs on 12.3 and your platform to rule out issue with code and 3660 , if you try to xmodem another image re-donwload a fresh code from cisco before downloading it to router.
jorge
