AXL: authenticationProxyRights
Dec 12th, 2007
Hi everyone,
I tried to set <authenticationProxyRights>false</authenticationProxyRights> and the result is:
"<authenticationProxyRights> is not a valid element of this request type."
although you will see this if you do a getUser.
Is this a bug?
Axel
p.s. CM 4.1(3) ES124
schemberg Fri, 12/14/2007 - 01:45
... solved my problem: it was an order problem.
I tried
- disable CTI
- disable CTI SuperProvider
- disable ProxyRights
and it works with the order
- proxyRights
- cti
- superProvider
regards
Axel
