CRA Editor
Dec 12th, 2007
Hi all,
I'm working with CRA Editor, version 3.5(3).
The issue is: when I began a new script, if I drag an object from the palette pane, and try to drop it into the Design Pane, the system don't let me do it.
Anyone have a clue?
Overall Rating: 5 (2 ratings)
clarkjason Wed, 12/12/2007 - 10:54
I have run into this before and I simply copy an existing script and rename it, I am then able to edit an existing one...
