Valcom V-1109RTVA and CM5.x
Dec 12th, 2007
I'm trying to understand some odd behavior we were experiencing to a Valcom V-1109RTVA in our pre-cutover testing last night.
The Valcom is connected via an FXO port on an MGCP-configured gateway. It is a 9-zone system and I beleive it only requires a single digit once tip/ring is closed. Our goal is to have users dial 79x, where x=zone. I received the following behaviors for each of the following route-pattern configurations:
Route Pattern:79.x
Discard Predot
Result: Busy Signal
Route Pattern:79.0
Discard Predot
Result: Nothing, but if you dial another digit (e.g., 7900, 7901, 7902, etc.) it pages to the proper zone.
If I waited a couple of seconds between 790 and the last digit "x", I would get a tone back from the Valcom unit, and no page worked. I assume this is a timeout.
So it appeared the only way I could get the Valcom to work was to send it a 0 first. Is this a timing thing with the Valcom? Is there another RP config I should try?
I had also tried RPs like 79.5 (discard predot) 79.2, etc. etc. without success.
Thanks in advance.
pvoss Sun, 10/12/2008 - 16:14
I have the same Valcom and an MGCP configured Gateway with FXO port. Exception is CM4. I can't get any response from the Valcom. Did you do anything unusual in the setup of the port to get the Valcom to respond?
Thanks in advance.
