PRI Signalling question
Answered Question
Dec 12th, 2007
When DTMF is transmitted across a PRI, is it sent inband across the B channel as part of the voice call, or is it sent out of band across the D channel?
Correct Answer by dgahm about 9 years 7 months ago
John,
Only call setup information goes across the D channel. After the call is connected, DTMF would be carried in band on the B channel.
You can do a debug isdn q931 on a PRI gateway router to verify this.
Please rate helpful posts.
Dave
Overall Rating: 4.5 (3 ratings)
Correct Answer
dgahm Wed, 12/12/2007 - 12:26
  • Blue, 1500 points or more
John,
Dave
jcmartin Wed, 12/12/2007 - 12:29
Thanks Dave. Don't tell the Cisco guys this, but it isn't plugged into a Cisco gateway, which is limiting my troubleshooting capabilities, but it's the customer requirement. But, this will certainly help point to where they need to make corrections.
yxsjwsb Fri, 12/14/2007 - 19:22
I hope this is helpful, you can download a graphical PRI debugger that parses q931 debugs at pippinsoftware.com It's demo, just 10 channels, since they are still in beta testing. Could be useful for general debugging.
yxsjwsb Thu, 01/03/2008 - 10:23
The full version of this is out now and it's very inexpensive.
