EZVPN with conventional L2L IPSEC VPN
Dec 12th, 2007
I have a client that has two PIX 515 at the hub site with about 80 remote L2L VPNs. I was thinking about moving to an EZVPN configuration in order to simplify the config and provide backup VPN capability. They are currently using static load balancing (half of the VPNs on one PIX and half on the other). Can the PIX 515 run in both modes (ezvpn and l2l)? I am concerned about messing with the config and dropping all the remote sites. Also can anyone give advice on whether this is worth doing or should I just use two set peer statements for each crypto map and duplicate the config on each unit? Any suggestions would be appreciated.
ivillegas Wed, 12/19/2007 - 12:01
PIX 515 supports EzVPN and L2L VPNs induvidually. But not usre if it supports L2L and EZVPN at a single point of time. Check if this is the configuration you are looking for. Change the configuration as per your requirement.
