Webvpn with Cert for Authentication
Dec 12th, 2007
I have an ASA running 8.0(2) that I'm trying to configure for webvpn using a client cert for authentication. I CAN make this work using AAA, but need to use both AAA and the client cert. This is the error I get when I try the cert:
INFO: debug webvpn enabled at level 255.
sslvpn# webvpn_portal.c:ewaFormSubmit_webvpn_login[1808]
ewaFormSubmit_webvpn_login: tgCookie = 0
ewaFormSubmit_webvpn_login: cookie = c946f7b0
ewaFormSubmit_webvpn_login: tgCookieSet = 0
ewaFormSubmit_webvpn_login: tgroup = NULL
Tunnel Group: EngineeringSSLProfile, Client Cert Auth Failed!
Embedded CA Server not enabled. Logging out the user.
I am able to login to the ASA with my OTP and get the client cert. I have installed it as well. Any help would be appreciated.
