12-12-2007 02:40 PM - edited 03-03-2019 07:54 PM
Hello Experts,
I need to configure a router so that it can detect when one gateway is down.
I was told that there is a command named "track" that sends a constant ping to detect if the gateway is up. If the ping is not detected then it will be sent via route-map to the other gateway. Anyone has some links to read on this? Or perhaps a configuration example using track?
Randall
12-12-2007 02:58 PM
Object tracking may help
Jorge
12-12-2007 10:01 PM
Yes tracking does work the way you heard, but it doesnt just use icmp but also udp or http get request. Tracking can be used in a number of ways viz with hsrp, routing, PBR etc.
If you are configuring HSRP & need to use tracking to monitor the interfaces then follow this link:
If you want to use PBR with tracking, then refer this:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080457bcc.html
hope that clarifies.
pls rate all helpful posts.
