Why can't I do a copy tftp:odran.txt nvram:startup-config - MDS9216A
Dec 12th, 2007
copy tftp:odran.txt nvram:startup-config doesn't like the word nvram although the following link on page 3-23 says I can do it.
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/sw/rel_1_x/1_0_2a/san-os/configuration/guide/MDSCnfig.pdf
Another document says I have to do
copy tftp:odran.txt system:running-config
and then do
copy system:running-config nvram:startup-config
I have worked on Cisco Routers and Switches and I find that file manipulation on MDS is more tricky.
Any suggestion?
astanislaus Thu, 12/13/2007 - 15:54
startup-config is not an allosed parameter for version 3.0.
We get a message saying
copy tftp startup-config command has been deprecated and says use sequence
write erase
reload
copy tftp running-config
Trending Topics: Storage Networking
