2 VLANs on 1 Port
Answered Question
Dec 13th, 2007
Hi all,
can i have 2 vlans assigned to 1 port with cisco switch 2970 ?
Correct Answer by royalblues about 9 years 1 month ago
You can have only a voice vlan and a data vlan associated with a Cisco switch port.
Narayan
Overall Rating: 5 (2 ratings)
Correct Answer
royalblues Thu, 12/13/2007 - 00:46
Narayan
majdalani Thu, 12/13/2007 - 01:38
So there is no way to have 2 data vlans on 1 port !!
Edison Ortiz Thu, 12/13/2007 - 07:03
You can trunk the switchport and purchase a NIC that is 802.1q aware.
If this switchport connects to another switch, then just configure both switchports as trunk.
A trunk allows you to carry multiple Vlans.
ashirel Thu, 12/13/2007 - 08:01
what is it that you wish to do?
a trunk port w/ multiple vlans may help.
older ios versions allowed multi-vlan ports.
this was phased out as the trunking standard
solidified.
-ams
(arthur sherman AKA avraham shir-el)
majdalani Fri, 12/14/2007 - 02:56
what i wish to do is having one machine to be able to work on 2 vlans using the same port without the need to change the access list on the main switch 4506.
This computer is connected to a 3750 switch on a port that is configure to vlax, now i want this port to be configured for vlanx AND vlany.
shiva_ial Fri, 12/14/2007 - 03:07
hi Tarek ,
you can have only one pc attached to one vlan (means a single port can be member of single vlan alone). my undertsanding is you want same pc connecting in single port to
participate in 2 vlans at same time (not possible i guess)
Edison Ortiz Fri, 12/14/2007 - 07:30
Definitely doable.
1) Purchase a NIC with 802.1q support
2) Configure the switchport as trunk
This procedure is done before on server farm environments where you have a VMWare machine hosting several VMWare hosts running on different subnet. The NIC allows you to allocate the host on the specified subnet.
majdalani Fri, 12/14/2007 - 09:23
Hi Edison,
Say that i have purchased a NIC with 802.1q support. what is next ?
what configuration should be done on this NIC ?
Edison Ortiz Fri, 12/14/2007 - 09:59
The NIC driver should allow you to configure dot1q trunking. The steps are different depending on the NIC driver, read its docs.
