ASA statistics and analyzer
Dec 13th, 2007
i need a small ASA analyzer that can tell me each IP usage in my network, i had a situation today in which there is a high traffic usage from my office and i couldn't know from which pc , i did show conn but i couldn't know who this pc was.
thank you
Overall Rating: 5 (1 ratings)
husycisco Thu, 12/13/2007 - 02:39
Hi Joseph
ASDM 6.0 has the top talkers monitoring option which fits your scenario. Also Adventnet Firewall Analyzer is a goo 3rd party software for achieving what you want and more
josephium Thu, 12/13/2007 - 02:47
thank you for your fast response, adventnet is kind of big and costly, and does ASDM 6.0 work with ASA 7.2 or should i upgrade to 8.0 ?
any other software suggestions ?
husycisco Thu, 12/13/2007 - 04:25
You should upgrade to 8.0
I used CSM (Cisco Security Manager) and Manage-Engine Firewall Analyzer as I suggested. But CSM is much more expensive. I used to try some other softwares in past, cant remember names really but they were useless. Best are above I mentioned.
husycisco Thu, 12/13/2007 - 06:01
IOS 8.0.3 and ASDM 6.0.3 rocks so far. Perfect improvement in SSL VPN and monitoring abilities of ASDM
kevin.jones1 Fri, 12/14/2007 - 04:08
AdventNet is ok, not that great. I used CSM in
the past and it is a horrible product from
I would use Sawmill. It's a cheap product
and can do what you need.
