no ip igmp snooping ? no explicit-tracking
Answered Question
hello!
i dont have this :explicit-tracking
DS2(config-if)#no ip igmp snooping ?
fast-leave Enable IGMP fast leave processing
last-member-query-interval Configure IGMP leave query timeout
mrouter Configure an L2 port as a multicast router port
querier Enable IGMP querier processing
ssm-safe-reporting Enable SSM Safe Reporting
static Configure an L2 port as a member of a group
<cr>
i dont have this :explicit-tracking::: on my 720:s72033-ipservicesk9-mz.122-18.SXE6a.bin
Correct Answer by Edison Ortiz about 9 years 4 months ago
try the command under the interface.
Overall Rating: 5 (3 ratings)
Edison Ortiz Thu, 12/13/2007 - 06:50
  • Hall of Fame,
    Founding Member
Hi Ali,
What's the problem you are trying to address here ?
Edison Ortiz Thu, 12/13/2007 - 08:39
  • Hall of Fame,
    Founding Member
Try
no ip igmp explicit-tracking instead.
Also, Explicit host tracking is supported only with IGMPv3 hosts. Are you running IGMPv3 in your hosts ?
Still no:
(config)#no ip igmp ?
immediate-leave Leave groups immediately without sending last member query, use
for one host network only
limit IGMP limit
snooping Global IGMP Snooping enable for Catalyst Vlans
ssm-map SSM mapping commands
vrf Select VPN Routing/Forwarding in
the is no explicit-tracking
Correct Answer
Edison Ortiz Thu, 12/13/2007 - 08:53
  • Hall of Fame,
    Founding Member
