VPN secure client, Internet connection and especial configuration
Dec 13th, 2007
Hi there,
I am using Cisco VPN client 4.8.01.0300 to establish a secure remote connection against Cisco 26oo gateway.
I have two issues:
When I establish connection, the internet connection of my client becomes unavailable. Is it possible to fix this behavior having both the vpn and inet connection simultaneously?
I have defined a pool for my remote customers. How can I make the remote clients get the same IP everytime they connect? I mean, based on the username the use to connect?
This is my configuration:
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group XXXXXXXX
key YYYYY
pool ippool
crypto isakmp profile VPNclient
description VPN clients profile
match identity group XXXXXXX
client authentication list clientauth
isakmp authorization list groupauthor
client configuration address respond
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dmapa 10
set transform-set myset
set isakmp-profile VPNclient
crypto map cmapa 10 ipsec-isakmp dynamic dmapa
Thanks in advance
