Strange Strange Brodcast
Edison Ortiz Thu, 12/13/2007 - 07:06
  • Hall of Fame,
    Founding Member
What is DS ?
Can you post the output from show interface g0/1 ?
hello edison!
ds:its distribution:
SW#sh interfaces gigabitEthernet 0/1
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
Link type is autonegotiation, media type is SX
output flow-control is off, input flow-control is off
Last input 00:00:00, output 00:00:03, output hang never
Last clearing of "show interface" counters 03:59:45
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 7006000 bits/sec, 7053 packets/sec
5 minute ouxtput rate 0 bits/sec, 0 packets/sec
102537443 packets input, 4241617996 bytes, 0 no buffer
Received 102361096 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 102195392 multicast, 0 pause input
4618 packets output, 862882 bytes, 0 underruns
Edison Ortiz Thu, 12/13/2007 - 08:55
  • Hall of Fame,
    Founding Member
wow, you have a ton of input traffic with no output traffic.
Did you try telneting to the device connected on G0/1 ? What type of device is connected to G0/1 ?
It looks like you have a virus.
Edison Ortiz Thu, 12/13/2007 - 09:29
  • Hall of Fame,
    Founding Member
Did you telnet to this switch and check the port counters to identify which switchport is the one sending the most traffic ?
mheusing Thu, 12/13/2007 - 09:36
  • Cisco Employee,
The first question coming to my mind: what is causing the broadcast traffic? Can you use a packet analyzer like Wireshark to record the packets utilizing a SPAN port?
This should help to identify the cause of the broadcast packets and thus maybe allow you to stop it at the origin.
I know some applications use broadcast to distribute data, which could explain the observed behaviour.
Regards, Martin
RouterTech1 Thu, 12/13/2007 - 09:52
so shut off the ipv6 on the clients that are trying to join... Vista has ipv6 enabled by default.
mheusing Thu, 12/13/2007 - 09:53
  • Cisco Employee,
Which source MAC address is seen? Track the source MAC address(es) to the switch port(s) connecting the end device(s). In some operating systems IPv6 is turned on by default (or misconfiguration by admins).
Once you know the end device you need to check the operating system settings. In MS you could simply disable the protocol for the network card in the LAN Properties Tab.
Regards, Martin
mheusing Thu, 12/13/2007 - 10:04
  • Cisco Employee,
Empty? you mean all zeros as source MAC address? A standard ethernet frame has to have a source MAC and a destination MAC. Can you attach a small sample of collected packets in a zipped file?
Regards, Martin
Danilo Dy Wed, 12/19/2007 - 06:58
  • Blue, 1500 points or more
Hi Ali,
Since the traffic is coming from the switch and you are sure that IPv6 is disabled in the switch. Can you post the "show version" output of the switch? It could be a bug.
Regardes,
Dandy
Danilo Dy Wed, 12/19/2007 - 07:50
Hi Ali,
show ipv6 interface [interface-id]
show ipv6 route
show ipv6 static
Make sure you don't use IPv6 first.
In the global configuration mode
SW(config)# no ipv6 unicast-routing
In the interface configuration mode
SW(config-if)#no ipv6 enable
Dandy
mheusing Sat, 12/22/2007 - 01:51
  • Cisco Employee,
have a look at the source mac addresses seen, which is HighTech_1d:b3:01 in the screenshot. Track the mac address in the switches to the access port (presumably "show mac-address-table") and have a look at the attached device. I would assume the source is not a switch, but a host with default IPv6 settings. Once you found the host(s), check the network card settings and disable IPv6, as you do not want it to be active. In case you do not know how to disable it, please provide more informations on the host(s) causing the issue.
In brief:
1) find access port in the switches by tracking MAC address
2) identify host connected
3) check network card settings connected to switch port
Regards, Martin
