ccmuser
when i type in my brouser
http://<CCM IP Address>/ccmuser
that time unauthorized????
mchandak
Level 7
Level 7
If you are running CM 4.1 and above, you would need to use the URL https://IP_Address_of_CM/ccmuser as CM 4.1 onwards does not support http.
Hope this helps
i am also type https. then also same problem is there any thing to enable in ccm. i am using ccm5.X????
