Confusion regarding CCDP Certification
Dec 13th, 2007
Passed the following exams:
642-901 BSCI
642-812 BCMSN
642-873 ARCH
However, the profile still shows CCDP as incomplete.
Can anyone help understand the reason.
Thank you.
mheusing Thu, 12/13/2007 - 09:03
If all the required exams are passed, which can be checked in the Certification tracking System tool
https://www.certmanager.net/cisco/login.aspx?ReturnUrl=%2fCisco%2fDefault.aspx
you can open a case in the Certification Online support
http://ciscocert.custhelp.com/cgi-bin/ciscocert.cfg/php/enduser/std_alp.php
They should either update your record to reflect CCDP or point out, what is missing.
Regards, Martin
hashsham1 Thu, 12/13/2007 - 09:20
Thank you for all the responses.
I have called in the certification support team and the case has been escalated to a certification expert.
As far as I have noticed 642-873 ARCH does not show any where in certification progress. The database still displays 642-871 ARCH as the only requirement for getting certified.
I will update when I get to hear back a reply.
hashsham1 Mon, 12/17/2007 - 09:38
Someone from Cisco certification team has made a manual entry for the CCDP certification under my profile and so the issue appears to have been take care of.
Thanks again for all the responses.
hashsham1 Tue, 12/18/2007 - 12:07
Yes as I mentioned that I called in and had a trouble ticket opened up with Cisco training support team.
They had someone from the certification team manually fix the problem.
You may do the same.
Monday through Friday from 5:00am to 5:00pm Pacific Time at 1-800-829-6387 (US/Canada) or 1+ 408-902-5200 (International).
