12-13-2007 07:52 AM - edited 03-15-2019 07:46 AM
I've got a CiscoCommunications Manager 6.0.1 Business Edition with a cisco2851 MGCP Gateway. As the server is installed in Germany I need isdn overlap send recieve. On the RoutePattern configuration page I entered 0.0!as RoutePattern and checked Allow Overlap Sending. The T302 Timer on the SystemParameter Page is set to default (15000). Some incomig calls can not be established as I don't recieve the whole number. See below a debug isdn q931 output.
Dec 13 16:48:26.700: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0244
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839D
Exclusive, Channel 29
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0x2181, '61967005743921245'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '140'
Plan:Unknown, Type:Unknown
Dec 13 16:48:26.740: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8244
Dec 13 16:48:31.696: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x1D9B
Cause i = 0x82E6 - Recovery on timer expiry
Dec 13 16:48:31.700: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x9D9B
Dec 13 16:48:31.700: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0244
Dec 13 16:48:31.716: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x1D9B
Dec 13 16:48:31.756: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8244
Dec 13 16:48:31.772: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0244
Dec 13 16:48:35.484: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x1D9C
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x00A3, N/A
Called Party Number i = 0xC1, '7007100'
Plan:ISDN, Type:Subscriber(local)
Dec 13 16:48:35.516: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x9D9C
Dec 13 16:48:35.516: ISDN BR0/2/1 Q931: TX -> SETUP pd = 8 callref = 0x26
Sending Complete
Standard = CCITT
Channel ID i = 0x8A
Exclusive, B2
Calling Party Number i = 0x00A1, N/A
Called Party Number i = 0x80, '7100'
Dec 13 16:48:35.548: ISDN BR0/2/1 Q931: RX <- ALERTING pd = 8 callref = 0xA6
Dec 13 16:48:35.556: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x9D9C
Progress Ind i = 0x8088 - In-band info or appropriate now available
Does someone have an idea what I have to change?
Peter
12-14-2007 12:08 AM
Are you using SIgnificant Digits (CCM) with a PRI MGCP Router`? if yes, this is not supported. Try to set the Significant Digits to ALL and route your Inbound Calls using translation Pattern. Also Make sure the Parameter "OverlapReceivingForPriFlag" is set to true.
12-19-2007 11:24 PM
You were right. After I removed the significant digits and added some Translation Patterns it worked fine. Thanks a lot!
Peter
12-14-2007 02:57 AM
In my German H323 Gateway, I've configured the overlap-receiving at my Serial Interface and this is working fine. Not sure if this is helpfull for you.
interface Serial0/0/0:15
no ip address
no logging event link-status
isdn switch-type primary-net5
isdn overlap-receiving T302 2500
12-14-2007 11:25 PM
I'm not sure what you need to change. You might look at downloading the PRI debug program at pippinsoftware.com - demo shows ten channels for free.
It basically gives you a gui from the q931 debugs.
12-22-2007 10:00 AM
The first beta of this PRI debugger had some issues, there's a revised beta posted at pippinsoftware.com now.
