FTP from VLAN1 to VLAN2 on a 3750 catalyst not possible
hi,
on a 3750 catalyst ( Version 12.2(25)SEE2 )
it's not possible to start a FTP from a client in VLAN1 to a server in VLAN2;
is the same client also in VLAN2 than it works fine...
there is no firewall/access list defined...
i get:
ftp> open xxx.xx.xx.xx
connected to xxx.xx.xx.xxx.
connection closed by Remotehost.
ftp>
a telnet and ping xxx.xx.xx.xxx is possible!
any help/idea?
thanks,
martin.
Anonymous (not verified) Thu, 12/13/2007 - 08:21
What are you using to route between the VLANs? Are you using the 3750 or an external router?
Brandon Buffin Thu, 12/13/2007 - 08:23
  • Purple, 4500 points or more
Martin,
Do you have the command "ip routing" in your config?
Brandon
b.petronio Thu, 12/13/2007 - 08:48
So, if u could ping/telnet it between vlan's, routing is fine.
Is there any acl filtering ftp traffic ?
Best Regards,
Bruno Petrónio
1) the routing is done by the switch itself
2) no i have no "access list"
3) yes, i have the parameter ip routing
here the starting from the config:
switch 1 provision ws-c3750g-48ts
switch 2 provision ws-c3750g-48ts
switch 3 provision ws-c3750-48ts
ip subnet-zero
ip routing
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
spanning-tree vlan 1,10-14 priority 24576
vlan internal allocation policy ascending
interface Port-channel1
switchport mode access
spanning-tree portfast
spanning-tree bpdufilter enable
interface Port-channel2
switchport mode trunk
shutdown
interface GigabitEthernet1/0/1
description S1svaEN1
speed 1000
duplex full
thx,
martin
Hi Martin
Are you sure that the problem is with the 3750?
From the FTP information supplied,
ftp>
it appears that you have been connected to the server and that something on the server has then ended the session.
If there was a routing problem on the 3750 I would have expected something like the following,
H:\>ftp
ftp> open 10.10.10.1
> ftp: connect :Connection timed out
ftp>
If the server is a windows based server, is it possible that there is a local firewall (windows firewall) terminating your FTP session?
Best Regards,
Michael
