FWSM Int problem
Dec 13th, 2007
I can't get the Vlan interfaces on the FWSM to come up because I don't have a phy int to bind them to... Anyone know how to do this?
Here's the relevent config for the fwsm:
interface Vlan100
nameif inside
security-level 100
ip address 10.254.254.203 255.255.255.248
and the 6506:
firewall vlan-group 4 100,200
vtp mode transparent
vlan 100
name Firewall_Inside
interface GigabitEthernet2/46
no ip address
switchport
switchport access vlan 100
switchport mode access
spanning-tree bpduguard enable
interface Vlan100
ip address 10.254.254.201 255.255.255.248
Overall Rating: 5 (2 ratings)
jaydhindsa Fri, 12/14/2007 - 09:39
You are missing:
firewall module x vlan-group y.
Where x is slot where ur module sits, and y is your vlan group that you defined. This will start trunking your Vlans to FWSM.
You also need
"firewall multiple-vlan-interfaces" if you are trunking more than 1 vlans.
Hope this helps.
Jay
RouterTech1 Mon, 12/17/2007 - 10:31
That was it.. thanks! I managed to get the answer a few hours before you posted this. But thanks!
berkous1 Sat, 12/15/2007 - 06:05
one thing seems to miss on your 6506 configuration :
Below please find an example :
This example shows how you can create three firewall VLAN groups: one for each FWSM, and one that includes VLANs assigned to both FWSMs.
Router(config)# firewall vlan-group 50 55-57
Router(config)# firewall vlan-group 51 70-85
Router(config)# firewall vlan-group 52 100
Router(config)# firewall module 5 vlan-group 50,52
Router(config)# firewall module 8 vlan-group 51,52
You don't need any physical interface to do that.
check on the FWSM is the Vlan is up. Don't hesitate to type "no shutdown" in the desired vlan config.
Hope it will help.
See ya?
