CSA Upgrade from 4.0.3.736 to 5.0.0.225
Answered Question
Dec 13th, 2007
Anyone know if there is a way to update directly from CSA 4.0.3.736 to 5.0.0.225? I prefer doing this with the CSAMC by scheduling a software update. I have another CSAMC currently running 5.0.0.225. However, CSAMC 4.0 lists 5.0.0.216 as the highest software update available.
Any suggestions?
Correct Answer by tsteger1 about 9 years 3 months ago
Did you run the 5.0.0.225 prepare_40_migration.exe tool on the old MC from a command prompt?
There were a couple of bugs that required this method to work properly.
If you started a previous migration or ran the 216 version of the tool, that would also explain it.
Tom
Overall Rating: 5 (1 ratings)
Correct Answer
tsteger1 Thu, 12/13/2007 - 12:58
  • Red, 2250 points or more
Tom
