Call Manager Express B-ACD with Call Manager 5 or 6
Answered Question
Dec 13th, 2007
Can I use the Call Manager Express B-ACD with Call Manager 5 or 6, because there is no autoattendant in CCM 5 or CCM 6
Correct Answer by Paolo Bevilacqua about 9 years 1 month ago
Yes, CM 6 has all the features of 4.3 plus the new ones.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Thu, 12/13/2007 - 13:26
beside that I understand AA is available in CM6, yes, certain B-ACD features would be usable when connecting GW to CM with H.323 or SIP.
zohaib.shabir Thu, 12/13/2007 - 21:45
Thank You,
So it means I can quote CCM 6 without any hesitation of AA autoattendant not available. I also needed a very basic auto attendant.
zohaib.shabir Sat, 12/15/2007 - 04:31
Dear,
Are you refering to the Mobile Voice Access Functionality or is there any other AA present in CM 6.
Thank you.
rob.huffman Sat, 12/15/2007 - 10:44
Hi Zohaib,
With CCM (all versions), they do ship with a "stripped down" version of IPCC/CRA which is where the actual AA is built. But this is not really an "on box" solution :( You will need a seperate MCS box to install IPCC on and then integrate with CCM via jtapi. Here is a clip and link for CCM 5.x and a link for 6.x which is a rather large PDF which I am having trouble downloading today;
Cisco CallManager AutoAttendant
Cisco CallManager AutoAttendant, a simple automated attendant, allows callers to locate people in your organization without talking to a receptionist. You can customize the prompts that are played for the caller, but you cannot customize how the software interacts with the customer.
Cisco CallManager AutoAttendant comes bundled with Cisco CallManager on the Cisco CallManager 5 agent IPCC Express bundle.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080531888.html#wp1026233
Check out the 6.1 Features and Services Guide here;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
Hope this helps!
Rob
