Uplink port changes to orange after 12-36 hours switch stops responding
Dec 13th, 2007
If I unplug the cable from the uplink port and plug it back it, the switch starts responding again.
What could be causing this?
mheusing Thu, 12/13/2007 - 10:27
  • Cisco Employee,
There are some features and bugs, which could cause this. Can you provide the respective switch port configurations?
Regards, Martin
abefroman99 Thu, 12/13/2007 - 10:34
Here they are:
The log on the switch in cabinet #1 is saying:
8w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
8w2d: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
8w2d: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
8w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
Log on the switch in cabinet #2 says something similar.
1d11h: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
1d11h: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
1d11h: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
1d11h: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to up
Both ports are set at 1000MBPS full duplex
cabinet #1
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0012.43a2.1719 (bia 0012.43a2.1719)
MTU 1500 bytes, BW 1000000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is RJ45
input flow-control is off, output flow-control is off
Last input 00:00:19, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2928000 bits/sec, 354 packets/sec
5 minute output rate 219000 bits/sec, 247 packets/sec
1837014603 packets input, 4093253980 bytes, 0 no buffer
Received 4121860 broadcasts (0 multicast)
9228 input errors, 9210 CRC, 0 frame, 0 overrun, 20795 ignored
0 watchdog, 269265 multicast, 0 pause input
1565825770 packets output, 1450541785 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
cabinet #2
GigabitEthernet0/2 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0015.63bb.6d1a (bia 0015.63bb.6d1a)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:00, output 00:00:06, output hang never
5 minute input rate 245000 bits/sec, 281 packets/sec
5 minute output rate 3324000 bits/sec, 398 packets/sec
21675498 packets input, 23077065 bytes, 0 no buffer
Received 655386 broadcasts (0 multicast)
0 runts, 6 giants, 0 throttles
8391 input errors, 8385 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 394750 multicast, 0 pause input
28663675 packets output, 2594052940 bytes, 0 underruns
mheusing Thu, 12/13/2007 - 11:02
  • Cisco Employee,
The information presented does not allow to finally conclude a certain reason. Could you provide the interface configurations?
Have you checked cabling as well?
Regards, Martin
abefroman99 Thu, 12/13/2007 - 11:10
>>What command do I type to get the output you are looking for?
>>Yes, I even tried a new cable.
mheusing Thu, 12/13/2007 - 12:06
  • Cisco Employee,
"show run interface GigabitEthernet0/1" with the proper interface numbers.
abefroman99 Thu, 12/13/2007 - 12:15
Thanks!
On the first switch its:
Building configuration...
Current configuration : 49 bytes
duplex full
end
on the second switch its:
show run interface GigabitEthernet0/2
Current configuration : 36 bytes
end
Are they suppose to be the same bytes?
mheusing Thu, 12/13/2007 - 12:23
  • Cisco Employee,
No, the number of bytes is just indicating how much data is used for storing this particular part of the configuration.
As the interfaces are in default configuration, I cannot see any reason for the observed behaviour.
Sorry not to be more helpful.
Regards, Martin
