Signatures for a recent CERT advisory...
Dec 13th, 2007
  • Cisco Employee,
For those who just might want to use the IPS to help detect and block sites listed in a recent CERT advisory.
Here's how you'd do it.
Both signatures are written using the ATOMIC-IP engine. I'll just point out the fields that need to be changed, I'll leave out things like sig name and severity, and you can change the actions to whatever you desire.
Case 1:
Traffic destined to some ip address aaa.bbb.ccc.ddd
sig-name connect to IP address xxx.xxx.xxx.xxx
> engine atomic-ip
> event-action produce-verbose-alert
> specify-ip-addr-options yes
> ip-addr-options ip-addr
> specify-src-ip-addr no
> specify-dst-ip-addr yes
> dst-ip-addr: aaa.bbb.ccc.ddd
Case 2:
A DNS query for something.
sig-name DNS query
> engine atomic-ip
> specify-l4-protocol yes
> l4-protocol udp
> specify-dst-port yes
> dst-port 53
> specify-payload-inspection yes
> regex-string (see below on what should be here)
For the dns regex, you need to be aware that the query will take the form of:
length-byte -- characters -- length-byte -- characters
So something like my.domain.com 2 characters, 6 characters, then 3 characters. Gets strung together as such:
\x02[Mm][Yy]\x06[Dd][Oo][Mm][Aa][Ii][Nn]\x03[Cc][Oo][Mm]
That is the regex to catch my.domain.com regardless of case in a dns query (UDP).
(note that the dots in the name, do not appear in the regex string)
