vpn connection with gprs
Dec 13th, 2007
hi
i have a problem with the vpn sessions,the users connect to internet with GPRS cards (wireless link) they are using the cisco vpn client 4.6.00 the problem is when in the configuration of the client check the option ipsec over tcp (see image) then the connection
drops every 10 or 15 minutes the pc have windows xp and are connecting to a cvpn 3005.
if i connect to internet with adsl, dial up, etc. there is no problem
but if i uncheck the ipsec over tcp and check ipsec over udp the connection works fine
i post the images with the log of the client
any ideas?
thanks
husycisco Fri, 12/14/2007 - 12:16
Hi Eduardo
Add the following command in VPN endpoint
crypto isakmp nat-traversal 20
Upgrade the client version to 5.0
If it doesnt work, that means GPRS card modem does not support transparent tunneling
