Dial-out connection issues - "No free dialer"
Dec 13th, 2007
We are attempting a dial-in connection to our equipment at site, with no success. The routers are configured identically (except for IP addresses and phone numbers) to other deployed systems with working dial-in access. We get past PPP Authentication, but then disconnect with a "No free dialer - starting fast idle timer" debug message.
Below is the debug output, and I will follow up with a post of the router config of the router we are dialing out from (phone numbers replaced with ######). Any thoughts or suggestions? Could a faulty modem at the dial-in location cause this? Thanks.
*Jul 24 22:12:26.010: As3 DDR: place call
*Jul 24 22:12:26.010: As3 DDR: Dialing cause ip (s=192.168.233.101, d=192.168.233.130)
*Jul 24 22:12:26.010: As3 DDR: Attempting to dial ########
*Jul 24 22:12:26.010: CHAT3: Attempting async line dialer script
*Jul 24 22:12:26.010: CHAT3: Dialing using Modem script: xz1 & System script: none
*Jul 24 22:12:26.010: CHAT3: process started
CHAT3: Asserting DTR
CHAT3: Chat script xz1 started
CHAT3: Sending string: AT
CHAT3: Expecting string: OK
CHAT3: Completed match for expect: OK
CHAT3: Sending string: ATDT ########
CHAT3: Expecting string: CONNECT
CHAT3: Completed match for expect: CONNECT
CHAT3: Sending string: \c
CHAT3: Chat script xz1 finished, status = Success
%LINK-3-UPDOWN: Interface Async3, changed state to up
As3 DDR: Dialer statechange to up
As3 DDR: Dialer call has been placed
As3 PPP: Using configured call direction
As3 PPP: Treating connection as a callout
As3 PPP: Authorization required
As3 CHAP: O CHALLENGE id 203 len 28 from "zz01rtr"
As3 CHAP: I CHALLENGE id 33 len 28 from "xz01rtr"
As3 CHAP: Using hostname from unknown source
As3 CHAP: Using password from AAA
As3 CHAP: O RESPONSE id 33 len 28 from "zz01rtr"
As3 CHAP: I RESPONSE id 203 len 28 from "xz01rtr"
As3 PPP: Sent CHAP LOGIN Request
As3 PPP: Received LOGIN Response PASS
As3 DDR: Remote name for xz01rtr
As3 DDR: Authenticated host xz01rtr with no matching dialer map
As3 PPP: Sent LCP AUTHOR Request
As3 PPP: Sent CCP AUTHOR Request
As3 PPP: Sent IPCP AUTHOR Request
As3 LCP: Received AAA AUTHOR Response PASS
As3 CCP: Received AAA AUTHOR Response PASS
As3 IPCP: Received AAA AUTHOR Response PASS
As3 CHAP: O SUCCESS id 203 len 4
As3 CHAP: I SUCCESS id 33 len 4
As3 DDR: dialer protocol up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Async3, changed state to up
As3 DDR: No free dialer - starting fast idle timer
As3 DDR: starting fast idle timer 16558 ticks
As3 DDR: fast idle timeout
As3 DDR: disconnecting call
%LINK-5-CHANGED: Interface Async3, changed state to reset
%LINEPROTO-5-UPDOWN: Line protocol on Interface Async3, changed state to down
%LINK-3-UPDOWN: Interface Async3, changed state to down
As3 DDR: re-enable timeout
kjander1979 Thu, 12/13/2007 - 11:02
The dial-out router config:
zz01rtr#sho conf
Using 2960 out of 29688 bytes
version 12.3
hostname zz01rtr
boot-start-marker
boot-end-marker
enable secret xxx
enable password enable
username yz01rtr password 0 xxxxxxxx
username dz03rtr password 0 xxxxxxxx
username pz01rtr password 0 xxxxxxxx
username xz01rtr1 password 0 xxxxxxxx
username xz01rtr password 0 xxxxxxxx
username xz01rtr2 password 0 xxxxxxxx
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
no ip cef
no ftp-server write-enable
chat-script rct "" "AT" TIMEOUT 120 OK "ATDT ########" TIMEOUT 120 CONNECT \c
chat-script dz1 "" "AT" TIMEOUT 120 OK "ATDT ########,,,,,,,,266" TIMEOUT 120 CONNECT \c
chat-script dz3 "" "AT" TIMEOUT 120 OK "ATDT ########,,,,,,,,8216" TIMEOUT 120 CONNECT \c
chat-script yz1 "" "AT" TIMEOUT 120 OK "ATDT ########" TIMEOUT 120 CONNECT \c
chat-script xz1 "" "AT" TIMEOUT 120 OK "ATDT ########" TIMEOUT 120 CONNECT \c
interface FastEthernet0/0
ip address 192.168.233.65 255.255.255.192
speed 10
full-duplex
no mop enabled
interface Serial0/0
no ip address
shutdown
interface Serial0/1
no ip address
shutdown
interface Async3
description Dial-up interface
ip address 192.168.233.129 255.255.255.192
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer in-band
dialer wait-for-carrier-time 60
dialer map ip 192.168.233.130 name xz01rtr1 modem-script xz1 ########
dialer-group 1
async mode dedicated
compress stac
ppp authentication chap
interface Async4
no ip address
router rip
redistribute connected
redistribute static
network 192.168.80.0
network 192.168.233.0
network 192.168.254.0
ip classless
ip route 192.168.80.0 255.255.255.0 192.168.233.130
ip route 192.168.177.0 255.255.255.0 192.168.233.130
ip route 192.168.233.0 255.255.255.0 192.168.233.130
ip route 192.168.254.0 255.255.255.0 192.168.233.130
ip http server
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
priority-list 1 protocol ip low tcp ftp-data
snmp-server community public RO
snmp-server community puplic RO
snmp-server enable traps tty
line con 0
line 3
modem InOut
transport input all
stopbits 1
speed 115200
flowcontrol hardware
line 4
stopbits 1
speed 115200
line aux 0
line vty 0 4
password xxxxxxxx
login
end
