JORGE RODRIGUEZ Thu, 12/13/2007 - 11:46
issue "no ip http server enable" on pix, PDM will not load if http is disable.
Jorge
JORGE RODRIGUEZ Thu, 12/13/2007 - 13:06
the command should be in your pix config towards the end, if you do "show run | inc http " you shoudl see it.
rwamstutz Mon, 12/17/2007 - 06:05
I do see that, when I execute that command, I only see: fixup protocol http 80
But I can not get to the pdm via https
jfbeam Mon, 12/17/2007 - 18:00
The default is off, so you won't see it in your running config.
