LordFlasheart Sat, 12/15/2007 - 10:23
GNS3 with a Cisco router that supports a switching module, otherwise just get the real thing if you can.
Chris
sgregg Sat, 12/29/2007 - 07:58
You can use something like dynamips with routers that support switching modules but realistically dynamips is better served for router labs. I would recommend finding an online lab, they are generally quite affordable. Just search Google for Cisco lab rack rentals. I havent used Boson in a while but last time I did I found it to be complete crap, you either need the real thing or an emulator, NOT a simulator.
Good luck.
-s
