allan.thomas Fri, 12/14/2007 - 13:43
  • Blue, 1500 points or more
When you have the opportunity please review the document at the following link, it comprises of all the TCP/UDP ports as used within CUCM 6:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/port/6_0/60plrev1.pdf
SCCP uses TCP port 2000
MGCP uses UDP port 2427 (Gateway Control)
MGCP uses TCP port 2428 (Backhaul)
Hope this helps.
Allan.
Pls rate helpful posts.
