Compatibility issues between ICM and MicroSoft Patches
Dec 13th, 2007
My remote site customer is running ICM SR6 ES 13 and is going to install MS07-063 through to MS07-069 Microsoft patches. Does anyone know if there are any issues that may occur with ICM after installing the above patches?
rlortiz Thu, 12/13/2007 - 16:53
Thanks for the pointer. Looks like the last tests that were done was with MS07-062. Do you think the next test with MS07-63 and greater will be done before the end of the year?
