problem with Hunt Group
Dec 13th, 2007
hello,
i have CCME, and i want to have hunt groups, but the called number must be the pilot. i know that it's not possible. i have configured
num-exp 123 999
ephone-hunt 1
pilot 999
list 123, 292
final 123
TIMEOUT 5
ePHONE-dn 1
call-forward noan 800 TIMEOUTS 10
Unfortunately, the voicemail is for 999.
123 : phone number
999 : dummy number
800 : Voicemail number
my need is the voicemail must be for 123 phone.
please help me.it seems very diffcult.
thanks.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Thu, 12/13/2007 - 13:55
  • Hall of Fame,
    Founding Member
Sorry, I read this three times but still cannot understand, what do you mean by you need voice mail to be 123? or what ?
dbenattou Thu, 12/13/2007 - 14:03
hello,
thanks for reply
my need iw when i call any number, if it not answers, ths call must must be forwarded to another, finally the call will be forwarded to voicemail, but we must have mailbox for the called phone not for the pilot.
296 ----> Pilot
123 --------> 292 '
voicemail (mail box 123)
thanks
help me please.
dbenattou Thu, 12/13/2007 - 14:05
please it's similar to this :
296 ----> Pilot ------> 123 --------> 292 -----> voicemail (mail box 123)
Rob Huffman Thu, 12/13/2007 - 16:18
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Driss,
Maybe you can take advantage of this (I think you are using CUE for VM?)
It is possible to have up to two numbers in the same Cisco Unity Express (CUE) User profile. Configure the first number as the Cisco Unity Express User Primary Extension, and the other number as the Primary E.164 number. However, only two Cisco Unified Communications Manager Express extensions are allowed to share the same mailbox in the Cisco Unity Express voicemail.
From this good Q&A doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_qanda_item09186a0080875c6f.shtml#q12
Place one ext in the primary ext field, and the other in the E.164 field
phonenumber - Specifies a number or extension for this user. No spaces or dashes are allowed.
phonenumberE164 - Specifies a telephone number with area code for this user. No spaces or dashes are allowed.
Example:
se-10-0-0-0(config)# username user3 create
se-10-0-0-0(config)# username user3 phonenumber 50180
se-10-0-0-0(config)# username user3 phonenumberE164 13335550180
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_administration_guide_chapter09186a00803ef7a7.html
In your latest example CUE is seeing the first redirected number 999, so try to enter 999 as the E.164 under 123's mailbox account.
Hope this helps!
Rob
esa786_2 Fri, 12/14/2007 - 05:56
Hi Rob. Thank you very much for your help to give nice answer to most of the voip problems.More over You are giving very good link with that answer which have very good information for the issue. Please continue this help on forums.Through your help lot of people are benefitting.
I hope you will continue this.
All the best
Esa
