Setup a CCM 5.1 Unix Loopback
Dec 13th, 2007
Can a loopback address be set on CCM 5.1? I am trying to setup a server cluster using SLB with two 6500 core switches to allow a third party redundant connection.
smalkeric Thu, 12/20/2007 - 13:53
  • Silver, 250 points or more
Are you tryig to configure loopback address for h.323 gateway and put the loopback ip address in the callmanager's gateway configuration page?
jamesek Thu, 12/20/2007 - 14:02
No. I am trying to setup SLB between the two callmanagers and one of the methods of SLB requires a loopback address on the CCM. I think I am going to use the direct method of SLB which does not requre loopback addresses.
Tim Smith Tue, 01/22/2008 - 07:27
Hi..
You cant set a loopback as such..
But you can multihome the server to 2 x different switches
You will need to enable NFT from the command line on the CallManager.
It will use an active / standby config. I.e. if one link fails and the server detects it, it will attempt to activate the other link.
Cheers,
Tim.
