2651xm VoIP GW basic questions
Dec 13th, 2007
I am lost among all sorts of port.
controller T1 0/0, I guess it refers to HW piece.
interface Serial0/0:23, This is logic port? what 0/0:23 stand for?
voice-port 0/0:23, what is that 0/0:23 again? underneath it is 23 ISDN-voice channels. Cisco refer a port as a T1 trunk?
and then,I have this again in ALL pots diap-peer:
dial-peer voice xx pots
port 0/0:23
Help!
Thansk.
Kenneth Mohammed Sat, 12/15/2007 - 11:05
  • Silver, 250 points or more
controller T1 0/0 refers to the hardware itself
int s0/0:23 is the D-channel for the PRI (this is where your ISDN config is performed)
the dial-peer configuration indicates that calls that match whatever destination pattern you have configured are to use voice-port 0/0:23 (your PRI).
hope that helps
