Password Reset Gone Bad
Answered Question
Dec 13th, 2007
A client has a Pix 515E which they don't know the enable password for. Their engineer attempted to perform a password reset but used the 6.3 utility on 7.2(2) code. All went well until the reboot when the system would not come back up... said the .bin could not be found and continuously rebooted... got the call for help and I TFTP pix722.bin, rebooted, it comes up, and passes traffic. However, during the boot process the following warning appears:
"WARNING: BOOT variable added, but not a valid image flash:/pix722.bin
*** Output from config line 23, "boot system flash:/pix72...""
Additionaly, enable mode is still not accessible.
<scratching head>
JD
Correct Answer by husycisco about 9 years 5 months ago
Hi Jonathan
When you TFTP the image to firewall in monitor mode, it opens up in memory first to boot, doesnt exist in flash. Thats why you see this error. Entering enable mode and copying the image with the following command to flash will solve the issue
copy tftp://tftpserveripaddress/pix722.bin flash:/pix722.bin
But for running above command, you need enable password. First you should reset the enable password. Follow the below guide
http://www.cisco.com/warp/public/110/34.shtml
Download the 7.0 bin, and apply the steps below PIX without floppy.
After you set your enable password and copy the image, dont forget to run
write mem
Another possibility is a corrupt image.
Overall Rating: 4 (1 ratings)
Correct Answer
husycisco Fri, 12/14/2007 - 00:38
  • Gold, 750 points or more
Hi Jonathan
write mem
jdlampard Fri, 12/14/2007 - 06:49
Thanks for the response. I understand the situation--just wasn't sure If once using the correct reset utility I would be good to go--also assuming the image is in place and viable.
Thanks again,
Jonathan
