7941 speed dial problem!
Answered Question
Dec 13th, 2007
Hi experts,
I got a user whose profile in CCM is 7941 and logged in 7941 unit. When config with speed dial, it don't appear. However when tired to login to another unit say 7960, it appears. Tried it myself & it works on 7960 but not on 7941.
Any related bugs?
thanks
Correct Answer by ananddiwakar about 9 years 2 months ago
Check the phone button template of 7941. Is it 1 line + 1 speed dial. In this case you will get one speed dial to configure.
Also, are you trying to configure using ccmadmin or ccmuser
Overall Rating: 5 (1 ratings)
Correct Answer
ananddiwakar Thu, 12/13/2007 - 21:32
redrobish Thu, 12/13/2007 - 22:03
The template is set to "Standard 7941". After setting it to line 1, all is good.
configuring on the user logon web
thanks
