Warning message
same-security-traffic
husycisco Fri, 12/14/2007 - 00:04
  • Gold, 750 points or more
Hi Aksher
This command is widely used for IPSEC traffic, for enabling Spoke-To-Spoke VPN. Lets say that you have a Site-To-Site VPN tunnel which ends at your outside interface. Consider them as "the two hosts" at outside. By default, traffic between these tunnels is disabled. And the above command permits the traffic enter and exit the same interface.
