Unable to ping
Dec 13th, 2007
We have pix 535, 6 interfaces, active stanby mode.In that 2 of the primary pix interfaces unable to ping from Secondary pix and vis versa.In that particular interface status are normal. Even i have checked with rebooting pix also.but i am finding input errors and overrun error in that particular interfaces. Kinldy provide me solution to solve the issue..
husycisco Thu, 12/13/2007 - 23:55
  • Gold, 750 points or more
Hi Sureshkumar
If you are trying to ping the inside interface from outside, yo should set the following
management-access inside
Also inspect ICMP traffic
policy-map global_policy
class inspection_default
inspect icmp
sureshkum Fri, 12/14/2007 - 01:00
Hi Huseyin Kayahan,
Thanks for ur response.but my question is somehow not clear.i think. Let us say again.As i told earlier. We have 4 dmz's, inside and outside interface. My problem is unable to ping primary Inside interface to Secondary inside interface.Same way prirmary one DMZ to the same Secondary DMZ's.I hope for that to receive pinging response, no need go for extra config.Because primary inside to secondary inside interface comes under same sbnetwork.More over rest of the 2 interfaces all other primary and secondary interfaces are pinging each other.
