LMS2.6 Customizable Groups under DFM
Dec 13th, 2007
can someone help me and explain how to work with it ? What are the difference between Customizable group 1 until C and the groups for Access Interface Trunk Ports ? Can someone help again and explain me how I can configure a switch to get only DFM alerts for a uplink problem and not for access port up down, also syslogs only for defined up-links ?
Great thanks in advanced for any help
Joe Clarke Sat, 12/15/2007 - 11:37
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Functionally, there are no differences between the lettered groups and the numbered groups. However, the lettered groups are designed for troubleshooting one device (though they may contain more than one device).
By default, DFM only manages uplink ports. Uplink ports are those that DFM determines are connected to other managed devices. So you should not be seeing events and alerts for access ports unless you've explicitly managed them. If you have managed them, you can go to DFM > Device Management > Device Details, and unmanage those ports.
To prevent syslog messages from being sent for access ports, you can turn off link messages for those ports in the configuration:
int fa1/0/1
no logging event link-status
steffen.plorin Sun, 12/16/2007 - 23:42
He Jclarke Danke again for answer, I will prevent the syslogging from it. Danke !!!
