BGP route not being advertised
Dec 13th, 2007
I have a route that I am trying to advertise to an external provider via BGP, but with no success.
- This is an EBGP connection;
- I have the route in my IGP table (OSFP);
- I have given the network statement in BGP to advertise the route;
- I have modified the prefix-list to include the new route to advertise.
However, even after all these changes above I cannot see the route being advertised to the provider.
Does anyone know what could be causing this issue please???
Thank in advance.
Jon Marshall Fri, 12/14/2007 - 00:16
Could you post relevant BGP config and a copy of the routing table.
Jon
adil.javid Fri, 12/14/2007 - 00:39
Sure, here is the relevant config:
network 211.14.0.0 route-map set-med-xxx-xxx
neighbor 199.72.199.12 remote-as 64960
neighbor 199.72.199.12 password 7 131610401F045427387426
neighbor 199.72.199.12 update-source Vlan70
neighbor 199.72.199.12 soft-reconfiguration inbound
neighbor 199.72.199.12 prefix-list ThomsonFinancial_Accept in
neighbor 199.72.199.12 prefix-list SG-To-Thomson out
Prefix-list:
ip prefix-list SG-To-Thomson seq 70 permit 211.14.0.0/16
Routing table:
xxxxx#sh ip bgp
*> 211.14.0.0 193.10.200 100 32768 i
Jon Marshall Fri, 12/14/2007 - 00:41
If you do a "sh ip route" is there an entry there. Could you post it.
Jon
adil.javid Fri, 12/14/2007 - 00:45
Yes, it is present in the IGP table:
xxxxx#sh ip route | i 211.14.0.0
O IA 211.14.0.0/16 [110/212] via 193.10.200 , 1w5d, Vlan10
Jon Marshall Fri, 12/14/2007 - 01:05
Sorry to keep asking for things but could you post full config of router as there is a route-map entry for example that is not included.
Jon
adil.javid Fri, 12/14/2007 - 01:10
No problem, I appreciate your help. The route-map is as follows:
route-map set-med-xxx-xxx permit 10
set metric 100
Thanks.
marikakis Thu, 12/20/2007 - 13:37
Try to avoid using the include in combination with the ip route command as you just did.
If the router that you issue such a command to also happens to have a large number of routes, you can potentially freeze the poor machine.
It is much safer and you even type less characters if you just type in: show ip route 211.14.0.0
This was obviously not a suggestion for solution of a problem that has already been solved. It just reminded me of my first big mistake in a router that was carrying many thousands of routes.
Kind Regards,
M.
milan.kulik Fri, 12/14/2007 - 14:48
I see a discreapancy in the subnet mask used:
but
Which means /24 mask used if nothing else specified.
If I understand correctly,
network 211.14.0.0 mask 255.255.0.0 route-map set-med-xxx-xxx
should have been used.
BR,
Milan
Danilo Dy Sun, 12/16/2007 - 19:58
ASN 64512 to 65534 is reserved by IANA for private use.
It can be use by SP and its downstream if the downstream doesn't have its own AS.
Dandy
CSCO10758684 Mon, 12/17/2007 - 09:14
Hai Dandy,
I was little confused with Privet As and Public ....now its clear ..that was my mistake ...thanks a lot
Lijesh.N.C
mheusing Fri, 12/14/2007 - 02:21
a couple of basic questions:
1) your BGP session is up, I guess?
2) How do you check that the route is not advertised?
3) your prefix-list statement has seq 70, post everything up to that entry!
4) Is the provider applying input filters blocking 211.14/16?
As a general remark: please do not cut or edit outputs unless you need to for security reasons. In this case, please replace the relevant statements.
I am assuming you would not be posting here, if you would not look for help. This usually means, that something relevant to the problem is not seen or understood. In this case to only post, what you are thinking is important will likely not reveal the underlying problem.
Regards, Martin
Danilo Dy Fri, 12/14/2007 - 20:01
After you've done with Milan and Martin's recommendation, don't forget to reset BGP so that your upstream will receive the changes that you've made. i.e.
clear ip bgp 199.72.199.12 soft out
Another recommendation (not related to your problem) is to use aggregation. i.e.
aggregate-address 211.14.0.0 255.255.0.0 summary-only
BTW, I see it being advertise as 211.14/21 using RIPE looking-glass. Are you changing the current advertisement from /21 to /16?
Dandy
adil.javid Tue, 12/18/2007 - 02:49
Thanks for everones inputs.
Last night we tried a clear BGP soft and both ends and the route started to be propogated.
Thanks to all.
shiva_ial Tue, 12/18/2007 - 01:01
may be synchronisation issue
your route will not be advertised to service
provider(another EBGP)until all IGP routers are aware of the route (all routers have same kind of information about the route)
so to override this
use no synchronisation command
experts can correct me if i am wrong, gives a learning edge as well
Kevin Dorrell Tue, 12/18/2007 - 02:17
You are right that if he is using synchronisation, the IGP should be aware of the route. Also that switching off synchronisation will remove that restriction. But I think that in this case the router does have a route. (Although Milan's issue about the mask still needs to be investigated.)
You might be interested to know that in the case of OSPF and BGP, synchronisation has one further special constraint. With most IGPs, the IGP just needs to know a route to the prefix, and BGP will be allowed to use it. But with OSPF, the originating router id must be the same as the BGP router id.
We could see all this information if the original poster could post a specific show ip bgp 211.14.0.0 for the route in question.
Kevin Dorrell
Luxembourg
marikakis Thu, 12/20/2007 - 14:21
I think the discrepancy in the subnet mask did not matter after all, because the prefix filter allowed "more" networks than the /24 implied by the lack of subnet mask in the network bgp command.
In any case, the exact intended mask should have been known and used, rather than depending on luck in order to see a 211.14.0.0 route being advertised, without paying attention to the mask that accompanies it.
The bgp implied a /24 network origination, the IGP route knew about a /16 and filter allowed a /16. So, I guess that the route that is actually being advertised after all is a /24.
Anyway, if you advertise less networks than you are assigned, problem will be in your network with some parts of it at some point being unreachable. Advertising more that you are assigned and your bgp peers finding it out is the humiliating scenario.
Kind Regards,
M.
milan.kulik Fri, 12/21/2007 - 00:15
IMHO, an exact match beween BGP network command and a routing table is necessary to advertise a prefix.
And also
does not permit /24 if LE or GE options are not used.
I agree with Kevin
show ip bgp 211.14.0.0/16 longer
would help to see what's going on there exactly.
BR,
Milan
marikakis Fri, 12/21/2007 - 05:05
"An exact route in the routing table is required for a network statement with a mask in order for it to be installed into a BGP table." from http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800945ff.shtml#topic4
Network statement did not have a mask as you have pointed out earlier in this discussion.
Wierd things can also happen with auto-summary enabled:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800945ff.shtml#topic1
Do you have any other documentation pointer that says something different?
You are right about the prefix-list, I have not looked at it thoroughly.
If we had all the config (that prefix-list could have other entries that allow the prefix to be advertised)
or some feedback about what actually changed besides a soft clear of the BGP session, perhaps we could solve the mystery.
Kind Regards,
M.
Kevin Dorrell Fri, 12/21/2007 - 05:23
Welcome back Marikakis! Looking forward to reading your postings once again.
Kevin Dorrell
Luxembourg
marikakis Sun, 12/23/2007 - 05:36
Hello Kevin! I always consider this forum great and great you are all of you people that spend so much of your time helping others! I hope I will soon have more time to catch up with your postings as well!
milan.kulik Sun, 12/23/2007 - 14:02
AFAIK, the BGP network ... command without mask opion is treated classfull, i.e.
network 211.14.0.0
should be the same as
network 211.14.0.0 mask 255.255.255.0
And even with auto-summary enabled, the prefix advertised would also be classful, i.e. 211.14.0.0/24.
I agree without knowing more config details and sh ip bgp 211.14.0.0/16 longer output we can only guess what's really happenning there.
BR,
Milan
