Blocking A Couple Of Numbers...
Answered Question
Dec 14th, 2007
Is it possible to block (Inbound) a couple of telephone numbers either in the CallManager or VoiceGateway?
Kind regards,
Sana
Correct Answer by allan.thomas about 9 years 7 months ago
Fortunately blocking or restricting the calling party number is only possible for H323 using translation rules, this is not the case with CallManager:-
1. Configure Voice translation rule.
voice translation-rule 1
rule 1 reject /number_to_block/
rule 2 reject /number_to_block/
2. Configure Voice translation profile.
voice translation-profile Calling_Block
translate incoming 1
3. Assing the Voice translation profile to the incoming pots dial-peer.
dial-peer voice xyz pots
translation-profile incoming Calling_Block
Hope this helps.
Seasons Greetings
Allan.
Overall Rating: 4.5 (2 ratings)
allan.thomas Fri, 12/14/2007 - 02:07
  • Blue, 1500 points or more
This specifically depends on whether you have configured the endpoint using either MGCP or H323?
Also is it the Calling Party or Called party number which you wish to restrict?
Please advise, and we will be able provide you with more detailed information on how to do. Either way it certainly is possible, but how you do it depends on the above.
Allan.
ysanadiga01 Fri, 12/14/2007 - 02:14
Hi Allan,
Thanks for your reply.
The eindpoint is using H323 configuration and I want to restrict the Calling Party (call originator) number.
Kind regards,
Sana
Correct Answer
allan.thomas Fri, 12/14/2007 - 02:54
Hope this helps.
Seasons Greetings
Allan.
noeparenteau Fri, 12/14/2007 - 07:01
Please excuse my ignorance, but I believe our account is configured with MGCP gateways, so am I out-of-luck in regards to the issue of having the ability to "block an incoming caller ID number"?
jvweigand Fri, 12/14/2007 - 07:21
Unfortunately, yes, there's no way to do it with MGCP, we just ran into the same issue a couple weeks back.
The only other option we could think of was to see if the Telco was able to block it on their end, which they couldn't do.
thurgoodj187 Tue, 12/18/2007 - 11:47
you could force the number through ipcc if you have it and block it through a script there, and then forward on to the DN if allowed.
