cisco 1812 dhcp problem
jarekgrzabel
I've got a question. I configured my cisco to give IP addresses automatically to other PC's on network. The problem is getting a new address or renewing takes a long of time. For example when I run my DHCP server on Linux then renewing and getting times of new addresses takes about few seconds. On Cisco it takes more than 20-30 seconds. Sometimes especially on OS's from Linux branch I've got timeouts and need to tune manually timeouts in dhcp-client.
Can I do something with it ? Are there any tips & tricks to tune dhcp server on Cisco ?
When I configure static IP for some PC's (f.e. servers) getting IP's times are the same.
p.s. Router is new and now it has basic configuration and for the present doesn`t have any ACL and firewall rules yet.
Is your dhcp client connected to a cisco switch? If so make sure port-fast is enabled on all ports that connect PCs. If this is not enabled their will be a delay until the DHCP discover packets are forwarded because the switchport is still going through all its STP timers.
10 Replies 10
Richard Burts
Jaroslaw
Taking that long to assign DHCP addresses seems unusual. Perhaps a good place to start would be to post the entire config of the router so that we might see if there is some config reason that impacts operation of DHCP.
If that does not reveal the problem it might be helpful to run debug for DHCP and to post the debug output.
Rick
Rick
Hi, thank You for an answer.
Here is my entire running config.
hell#sh run
Building configuration...
Current configuration : 4032 bytes
version 12.4
service password-encryption
hostname hell
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 xxxxxxxxxxxxxxxxx
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.0
ip dhcp pool SERWER
host 192.168.0.10 255.255.255.0
hardware-address 001a.6449.a8d2
default-router 192.168.0.1
dns-server 192.168.1.1
ip dhcp pool LAN
network 192.168.0.0 255.255.255.0
no ip domain lookup
crypto pki trustpoint TP-self-signed-2576536838
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2576536838
revocation-check none
rsakeypair TP-self-signed-2576536838
crypto pki certificate chain TP-self-signed-2576536838
certificate self-signed 01
!!!!certificate here!!! quit
username xxxxxx privilege 15 secret 5 xxxxxxxxxxxxxx
interface FastEthernet0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet2
switchport access vlan 2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1452
interface Vlan2
description LAN
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 192.168.0.0 255.255.255.0 Vlan2
ip route 192.168.1.0 255.255.255.0 FastEthernet0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat translation timeout 180
ip nat translation tcp-timeout 600
ip nat inside source list SIEC2NAT interface FastEthernet0 overload
ip access-list extended SIEC2NAT
permit ip 192.168.0.0 0.0.0.255 any
no cdp run
control-plane
banner login ^C
Sun Microsystem.
^C
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
end
Jaroslaw
Thank you for posting the config of the router. I do not see anything in it that would explain the delay in processing DHCP. Perhaps it would be helpful if your could run debug dhcp and debug ip dhcp server events and post the output.
Rick
Rick
The problem is the hostname on your router of 'hell.' Telling packets to go to 'hell' always causes an issue. Packets don't like to be told that...
Okay, seriously, like Rick said, post your debugs. :)
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
I followed by your issues and the configuration shown below gives 100% success.
duplex full
speed 100
spanning-tree portfast
I specified also duplex mode and speed not to let router and PC negotiate that values. Now not many devices works on 10 MBits so the negotiation is not useful.
I have found an cisco webpage with manual where is described that kind of problem. I pasted it for anyone who would have a problem with it.
http://www.cisco.com/warp/public/473/12.html
Thanks anyone for help me :-).
Jarek
p.s. ccbootcamp ;-)... yeah I wondered if that 'hell' hostname won`t be a problem and I had an idea to rename my router but I still belived that it can`t be a problem ;-). God loves us ;-).
Glad you fixed your prob. But I would still take a look at the debugs if I were you so you can understand what was happening with the packets a bit better. It's a great troubleshooting step you can utilize in the future. :)
-brad
www.ccbootcamp.com
Hi :-).
I have watched on debug infos, but nothing special there I saw. Everything works fine for me now. I`m preparing device to work and we will see after new year how does it handle it on all PC's in company (about 60). If it won`t work I will not have time for play with it and will need to run alternate dhcp server on Linux until I will not find a problem.
Anyway I`m sure everything will work fine ;).
Jarek,
Not sure if you did this or not yet but:
I noticed that you hard coded the speed and duplex on the switch ports. In order to achieve maximum performance you'll have to hard code the speed and duplex on the workstations NIC's themselves or there will be a miss match.
Craig
Hmm.. I thought hard coding duplex mode and speed of switch port will give me maximum performance because when they will not need to negotiate that values but router enforces them to workstation, doesn't it ? The time should be shorter because negotiation process of that values will be hard coded. Anyway at the present NIC's don`t need to work in 10Mbps. The minimum value is 100Mbps.
From the other way to the swichport will be connected only server and the other switch which will connect all the other stations.
Jarek
