CiscoView 6.1.6: showing PoE info
Dec 14th, 2007
Is it possible to show PoE information, i.e. power consumed by devices plugged in a switch ? In CiscoView 6.1.6 or any LMS 3.0 software ? This information is visible on http management interface of the device.
Moreover when right clicking on a 3750-PoE switch there is a PoE menu but it tells me that the Snmp agent or IOS version doesn't support this feature. have I missed something ?
Thanks.
Joe Clarke Fri, 12/14/2007 - 09:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
CiscoView 6.1.6 does add PoE support. However, in order for CiscoView to do any PoE management, the device must support the POWER-ETHERNET-MIB. What version of software is your 3750 running?
