VoIP documentation
Answered Question
Dec 14th, 2007
im looking for voip documentation for simple thing not so advantage...just connecting to offices over a serial line .
thanks
Correct Answer by Dennis Aston about 9 years 7 months ago
VoIP is a description of a combination of technologies and those in general are pretty technical kinds of things.
Here is something you might try but I don't know if it will give you enough detail to answering the question you asked.
http://www.ciscopress.com/bookstore/product.asp?isbn=1587201623
This book however is probably what you need and although not "simple" its not too hard to read and its what I started on (well, the first edition anyway).
http://www.ciscopress.com/bookstore/product.asp?isbn=1587052571
Overall Rating: 5 (1 ratings)
Correct Answer
Dennis Aston Fri, 12/14/2007 - 09:25
