DRAM and FLASH
qwertys21
I need to replace the IOS on a Cat 3550. Looking at the website I see
DRAM: 64M Flash: 16MB
When I do a show flash or show boot flash, I see the flash but where do I get the DRAM from?
Hi ,
In every device of Cisco , some part of DRAM is reserved for IOMEM i.e in your case 8192K.
DRAM SIZE = 65526K + 8192K = 64Mb.
Flash size = 16Mb.
Below are for your knowledge's sake.
Before you install a new Cisco IOS Software image on your router, check if your router meets the memory requirements for that image. For this, issue the show version command on your router, and look for these lines:
cisco RSP4 (R5000) processor with 65536K/2072K bytes of memory
16384K bytes of processor board System flash (Read ONLY)The first line tells you how much Dynamic RAM (DRAM) and Packet memory are installed in your router. Some platforms use a fraction of their DRAM as Packet memory. The memory requirements take this into account, so you have to add both numbers to find the amount of DRAM available on your router (from a memory requirement point of view).
Example 1: Separate DRAM and Packet Memory
...The 4000, 4500, 4700, and 7500 routers have separate DRAM and Packet memory, so you only need to look at the first number. This shows that the router has 65536 K (or 64 M) of DRAM.
Example 2: Combined DRAM and Packet Memory
cisco 2611 (MPC860) processor (revision 0x202) with 29696K/3072K bytes of memory
...The 1000, 1600, 2500, 2600, 3600, and 7200 routers use a fraction of DRAM as Packet memory, so you need to add both numbers to find out the real amount of DRAM. In this example, the router has 2969 K + 3072 K = 32768 K (or 32 M) of DRAM.
Example 3: Available Flash Memory
16384K bytes of processor board System flash (Read ONLY)The bottom line tells you how much Flash memory is available. Some of it might already be in use. In order to find out the amount of free Flash memory, issue a show flash command:
Router#show flash
System flash directory:
File Length Name/status
1 8407884 c2600-io3s56i-mz.121-6
[8407948 bytes used, 8369268 available, 16777216 total]
16384K bytes of processor board System flash (Read/Write)
satish
smothuku
Level 7
Level 7
Hi ,
When you execute the command " show version" you can see the size of the DRAM.
i.e
#sh version
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA6, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 21-Oct-05 01:59 by yenanh
Image text-base: 0x80010000, data-base: 0x80568000
ROM: Bootstrap program is C2950 boot loader
System restarted at 18:04:09 IST Mon Mar 5 2007
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA6.bin"
cisco WS-C2950G-48-EI (RC32300) processor (revision Q0) with 21013K bytes of mem
ory. -----------shows the DRAM Size....
i.e 21013K is the size of DRAM.
satish
On the Cat 3550
I see
cisco WS-C3550-48 (PowerPC) processor (revision L0) with 65526K/8192K bytes of memory.
and then I do sh flash
Directory of flash:/
15998976 bytes total (9575424 bytes free)
Pls can you explain which is which?
65526K --
8192K --
15998976 ---
Hi ,
Flash size = 16Mb.
Router#show flash
satish
Thank you very much
