Multiple SSID on 1242
Dec 14th, 2007
Dear Sirs.
I have 1242AG access point. I need to create two SSIDs for different types of devices. I create one SSID with WPA TKIP security and another one without security. I create two VLANs for each SSID, one of the VLANs is native VLAN.
In event log I see that devices associate to both SSIDs. However, I can ping from the network only the device which is assigned to Native VLAN.
When I switch Native VLAN to another SSID, devices within this SSID are being seen from the network, devices within second SSID are not seen (and vice versa).
Pleae advise.
Richard Atkin Fri, 12/14/2007 - 17:25
Could be a whole host of things... Easiest option is to post the switchport config from the switch, and the AP config.
Failing that, check that...
VLAN tags & encapsulation types are correct.
Routing is setup correctly
No ACLs / Firewalls
Bridge Groups setup correctly (Native VLAN is normally reserved for BVI 1, and not mapped to an SSID)
