12-14-2007 06:59 AM
trying to delete a device by using
/usr/bin/env DCRCLIFILE=./.passwd /opt/
CSCOpx/bin/dcrcli -u admin cmd=del id=xxx
This error occurs:
<dcrcli> * Password file found using DCRCLIFILE environment variable.
Error in Delete Device: Device is still managed by application(s)
Is there a way to force the delete procedure?
12-14-2007 07:27 AM
Yes if you're using 3.0, theres a -f" "force" switch avaialble for the delete command.
12-14-2007 07:35 AM
so is it:
dcrcli -u
thanks
12-14-2007 07:47 AM
ok it's
dcrcli -u
thank you very much
