IOS Modularity
Answered Question
Dec 14th, 2007
Folks:
Does anyone on this board have experience working with the "IOS modularity" infrastructure?
I understand what it is, but what I dont get is how one goes about obtaiing a modular version of IOS and installing it.
Are there new IOS versions that are modular? If so, in what version of IOS was modularity first introduced? Whoch are the modular versions of IOS and how do you know which they are?
Or do you keep the current version of IOS you are using and download some code from Cisco to make it modular (this seems wrong, since modularity reflects a total revamping of the code's logical infrastructure).
This is where I am confused.
Correct Answer by Edison Ortiz about 9 years 1 month ago
> So, I have been deploying 12.2(18)SXF7 since early this year. Is that a modular version?
Victor,
There are 2 types of 12.2(18)SXF7, the modular version and the non-modular version. You can tell which version you are running by typing show version on the switch.
> If so, how does maintenance of that code differe from other codes?
You can download patches that addresses a specific bug without upgrading the whole IOS.
> Does Cisco send out periodic patches for this code?
Yes.
> Do you have to request them?
Depends on the patch.
Overall Rating: 5 (1 ratings)
Edison Ortiz Fri, 12/14/2007 - 07:52
Yes, if you go to CCO and try to download a 6500 IOS, you will see something like this:
IP SERVICES SSH LAN ONLY
IP SERVICES SSH LAN ONLY (MODULAR)
Cisco Catalyst 6500 Series Supervisor Engine 720 Release 12.2(18)SXF4 and higher.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_promotion0900aecd80312844.html
lamav Fri, 12/14/2007 - 09:22
Hey, Edison: Thanks, man.
So, I have been deploying 12.2(18)SXF7 since early this year. Is that a modular version? If so, how does maintenance of that code differe from other codes? Does Cisco send out periodic patches for this code? Do you have to request them?
Correct Answer
Edison Ortiz Fri, 12/14/2007 - 09:56
Victor,
Yes.
lamav Fri, 12/14/2007 - 10:00
Edison, thank you once again. You are a gentleman and a scholar. :-)
