Access ASA 5510 via SSH on opposite interface
Dec 14th, 2007
We have a remote office with a 5510, and we are trying to access the asa 5510 via the ip address configured on the inside interface (the interface facing the renmote office, not the wan). We can access the outside ip address fine, but cannot access the inside ip address. Is this possible? Also not, this is a private wan circuit, and not a vpn tunnel terminated on the firewall. Thanks
husycisco Fri, 12/14/2007 - 08:01
Hi Shawn
So your remote office is connected to inside with a different network correct?
Try the following command
management-access inside
