Curiosity question only.....
Dec 14th, 2007
All, Im curious as to why, when you upgrade an IOS on a router or switch using TFTP, sometimes the exclamation points, during the tftp process, goes fast, and sometimes it goes slow. Why is that?
jmartell Fri, 12/14/2007 - 10:07
The donwload is slow which could be for many reasons, but one thing you can check is make sure you don't have any mismatch in terms of half/full duplex on the link.
++jose
jjoseph01 Fri, 12/14/2007 - 10:26
Yeah, thought about that, but had this on the same router. Did the first upload and it went really quick. Decided to put a different IOS on and it went really slow the second time. Its a gig port, and I have a little home switch that does auto-negotiation. Router set to auto as well. Hmm. Not sure.
ccbootcamp Fri, 12/14/2007 - 10:28
  • Gold, 750 points or more
good thing you're not a cat...
check your link speeds. that is most likely the issue, unless you had a bunch of other traffic going on during the slow IOS tftp.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
