video codec and dial-peer
Dec 14th, 2007
under dial-peer command, there are video codec h261/h263/h264. My question is:
1. What is the default video codec in cisco gw?
2. If no DSP, one video end station use h261, the other use h263, it won't work?
Overall Rating: 4 (1 ratings)
Brandon Buffin Fri, 12/14/2007 - 13:04
  • Purple, 4500 points or more
There is no default video codec which leads to transparent codec operation. This means that the codec is negotiated between the endpoints. See the following link.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a7f5c.html#wp1109047
There is currently not a transcoder to transcode video codecs. In the case of endpoints with different codecs, you would need another device such as an MCU.
Hope this helps. If so, please rate the post.
Brandon
